NC35/30 rear sprocket
saltysealion
I know the stock teeth count is different but are the dimensions/fitting the same?
IE, can I order a NC30 525 sprocket and slap it onto a NC35?
Some webpages just don't list a NC35, but they do for the NC30..
SPOONDIDDLY
Re: NC35/30 rear sprocket
Yes, they are the same
hunter
Yep same.
saltysealion
Thanks, helps a lot with some sites that list VRF but not RVF.
I can easily request 38Ting to stay stock :)
- JZH
- Bike owned: RSCBRRVFVFRST
Same as RC30, innit? The sprocket carriers are the same, bar the colour.
Ciao,
Ciao,
- RickOliver
Yes, the NC30, NC35 & RC30 all use the same rear sprocket - take note that if you are fitting a 525 sprocket the machined recess faces inwards, not outwards i.e. unlike most bikes the sprocket is offset towards the wheel, not away...
Rick
Rick
saltysealion
Hi Rick,
I'm a little confused.
One side is flush flat, the otherside has a ring protruding. Are you saying that the flush side should be on the outside?
- NGneer
Saltysealion - Yup that is exactly what he is saying Flat side of the sprocket facing outwards - ie to the left as you are sat on the bikesaltysealion wrote: Sun May 13, 2018 2:19 pm Hi Rick,
Now you know this you will see loads fitted the wrong way around, but obviously it doesn't seem to cause any great issues.
saltysealion
WOW, thank you so much. I was about to install it on the wrong way!
- NGneer
Easily done and instinctively you would think it should go the other way around.saltysealion wrote: Tue May 15, 2018 3:49 pm WOW, thank you so much. I was about to install it on the wrong way!
Once you know you will see so many fitted the wrong way around but without any major issues that I am aware of, so can't be too much of an issue
