Open / close throttle driveline shunt
andut1
- Bike owned: NC30 & 400/4
Ever since I have had my NC30 it's been a little 'clunky' when initially opening or finally closing the throttle, especially noticeable at low speeds - not a massive problem most of the time, but sometimes a little annoying in traffic. Is this a normal NC30 'characteristic' or something that can be adjusted / tuned or repaired ?
Thanks for any thoughts or suggestions !
Andy
Andy
- gavins
- Bike owned: NC30, ER6f, K5 750
Re: Open / close throttle driveline shunt
First thing that springs to mind is too much chain slack. Is your chain properly adjusted?
magg
- Bike owned: VFR400
No rubber in the drive train like most road bikes means that it can be a little clunky/snatchy when on/off throttle is not perfectly smooth.
you'll get used to it :) it is a feature of no cush drive as magg said.
andut1
Thanks gents - good to hear it's likely to to be normal !
could also be rough if the carbs are not set up quite right, having a properly dialed in low end does make a lot of difference on a biek without a cush-drive.. pilots could be too lean / rich (dirty or clogged / pilot screws open too much)
carbs out of balacne.
the lack of cush drive will make the grab a bit rough if your not smooth on the throttle.. if its jerky uneven it might be carb settings.
moforockband
Use a front sprocket with rubber damping will alleviate some of the issue. Pretty sure my original 92 nc30 had a rubber damped sprocket from brand new.
hunter
If i remember rightly so did the rear.
