Vfr 400 possible fuel starvation
Jaq213
Post by Jaq213 »
Hi all,
My vfr 400 has started to give what I think is fuel starvation at 5500rpm. Just backs off. Idles fine and goes fine till that threshold . Any ideas?
gavins
Bike owned: NC30, ER6f, K5 750
Re: Vfr 400 possible fuel starvation
Post by gavins »
Will it just not rev past 5500ish at any time, i.e in neutral as well? Assuming an NC30 and assuming the speed restriction hasn't already been bypassed, check that the 3 pin connector from the back of the speedo is connected properly. If this is disconnected altogether the bike just won't rev past 5k from memory.
^^ what he said :)
Welcome to the site.
Have a search for 5500rpm or 5.5k and you will find oodles of data - the bottom line is that if the bike CDI cannot "see" the speedo then it cuts 2 cyls.
Easy fix and we've all been there!
Jaq213
Post by Jaq213 »
Thanks for the reply. I'll check that out after work and let you know.
Jaq213
Post by Jaq213 »
Hi guys, checked all connections but problem persists. 😭
magg
Bike owned: VFR400
Post by magg »
The detector electronics in the speedo could be faulty. As already suggested, disconnect the 3 pin connector from the speedo and apply the bypass to the loom side. The document library on the home page has instructions.
Post by Neosophist »
as magg has said... remove the speedo sensor plug and jumper the wire.
Jaq213
Post by Jaq213 »
Thanks guys. Followed instructions and all sorted. Thank you very much.
