NC29 half empty radiator. HELP !
PTsakthi
Re: NC29 half empty radiator. HELP !
Post by PTsakthi »
just as my HC tester arrived, i found another leak. Not sure if this leak was there from the beginning, but i am gonna switch out the hoses and test it once more....
Bowches
Bike owned: cbr 400 zxr 400 gsx 1300r
Post by Bowches »
Hey where abouts are you from? Are you sakthi96 on instagram?
I am bowches with the orange Honda CBR 400 Repsol.....I go to Madras every year....if you need anything let me know. Are you from Sri Lanka?
PTsakthi
Post by PTsakthi »
found a leak at a 'T joint' on the left side of the bike. its a small hose connecting from the engines coolant pipe to the radiator. Anyone knows whats this hose is for ?
there is a consistent drip of coolant coming from it during idling.
not sure if this small amount of the drip is enough to cause so much problem, and for it to lose that much coolant in that amount of time...advice ?
dunkenb
Regular Member
Post by dunkenb »
Those small hoses allow coolant to circulate before the engine’s warm and the thermostat opens. They get quite brittle with age. If you can afford it get a full samco set. Or otherwise take a piece to a bike shop to get a replacement piece the same size.
