Crankshaft swap for NC23
900triple
Post by 900triple »
The big end on my NC23K has gone - I have a spare CB1 engine which appears to be in good condition - can I swap over the crank assembly/pistons/barrel for the CB1 straight into the original NC23 engine?
Also - any ideas where to get a full engine gasket set for the engine?
Ta
Bowches
Bike owned: cbr 400 zxr 400 gsx 1300r
Re: Crankshaft swap for NC23
Post by Bowches »
I think there are some similarities with the NC23 and the CB1....The CB1 also known as the NC27.
iF YOU Look at a NC27 engine, it kinda looks like the NC23 engine as well.....I'm not sure really
CB1pod70
Post by CB1pod70 »
The CB1 engine is basically the same as the NC23 from the cylinder head down. To do the swap, the easiest is to fit the NC23 head & cams including the 2 water outlets, water pump & oil cooler (behind the oil filter) and ignition pick ups to The CB1 engine this will get you going again. You may find the gear ratios are a bit different but actually more suited to road riding also you might want to swap the clutch baskets as the nc23 unit is lighter
I think that's everything I can remember from swapping parts between the 2 bikes
CB1pod70
Post by CB1pod70 »
GF racing, CMSNL or David Silver spares can sort out the gaskets for you. Don't bother with the cheap Chinese eBay ones as they are miles out
