NC35 Fork/Yoke and Geometry Settings
SPOONDIDDLY
Post by SPOONDIDDLY »
G'day guys,
I have searched but couldn't find any information.
I am wondering how far your fork tops are sitting above your top yokes on your NC35? Mine are currently sitting almost flush, but as my bike is mostly used on the track I would like to make sure that the geometry is set up correctly.
Currently the bike squats a fair bit when coming out of corners but that will also be because of the shagged shock NC30 shock that is currently in there, which will be getting rebuilt and set up correctly soon.
I have had the forks rebuilt and it handles beautifully but i'd like to hear your experiences with different geometries.
Any help would be greatly appreciated.
SPOONDIDDLY
Re: NC35 Fork/Yoke and Geometry Settings
Anybody able to shed some light on their setups?
jedidude04
Bike owned: RVF400
Post by jedidude04 »
From what i know, lowering the forks/raising the rear will increase your turn in. From what i've seen you might be better off raising the rear with a shim or height adjustable shock? I have used a taller shock with shorter dog bones on another bike to raise the rear and it made a massive difference to its flickability.
forks should poke through the yokes a little bit, 5-10mm from memory. Your current setup with a knackered shock isnt helping matters but until you have a decent rear shock sorted you may aswell be pissing into the wind.
If you have a 35 not a 30 then raising the rear is easy, a decent shock will raise it anyway but it can also be shimmed up to increase the height, id steer away from shortening the link as it increases the already high rising rate of the rear suspension which leads to more problems.
Foxy400
Regular Member
Bike owned: NC35 NC29 Bonneville Daytona
Post by Foxy400 »
Just nipped into the garage and measured the distance you asked about. My forks poke through the top yoke by 3.5 mm. Hope that helps.
SPOONDIDDLY
great, thanks guys!
Has anybody with a rebuilt NC30 shock on their NC35 needed to shim it up or found better results when doing so?
I agree that I need to have the shock rebuilt before I can really focus on the geometry but if I can get an idea of some good starting points and possibly shim the rear while I have the shocks out it'll make life easier.
Tim400GB
Post by Tim400GB »
You might be trying to run before you can walk here (not trying to be insulting).
There's not much point worrying about a few mm here or there if you've got a 20 year old shock on it.
A good starting point would be to get the rear shock replaced/rebuilt and put Rick Oliver's fork upgrade kit in the front.
SPOONDIDDLY
Yeah I agree, I will be getting the shock rebuilt for my weight and riding style in the new year but was just hoping that people could pass on their experience with shimming the rear/dropping the front and the effects that it had on handling
fourfingers
Bike owned: NC30RK,NC35RR
Post by fourfingers »
And a year later...Was trying to figure out mine and came across this post. 12mm over the top yoke, measured including fork caps. That is using circlips on the fork bottles and original clip-ons.
SPOONDIDDLY
How did it affect the handling?
I have my Nitron shock installed which has jacked up the rear and it is performing really well so I might start to experiment with dropping the front slightly if there are benefits to be had.
