Filters?
Tarlowb
- Bike owned: CB400SF NC39, '88 NC23 tri-arm
Filters?
Hey everyone
I am in the process of changing all the fluids and filters on the new super four, and whilst I have ordered a new air filter, oil filter, some new oil, I can't find any fuel filter on this bike.
Had a look through the past posts and used the search but no luck. I thought all bikes had fuel filters?
Forgive me if I have missed something super basic, I have changed them on other bikes but I can't see one on this bike, only the part that connects the tank to the carb hose with the little diaphragm that only allows fuel to flow under vacuum.
Does the cb400 super four hyper vtec spec II have one, or am I being daft?
Thanks in advance!
Sent from my E6653 using Tapatalk
Thanks in advance!
dobbslc
Re: Filters?
There's probably one in the tap assembly, you can fit an extra one in the fuel line between tank and carbs if you wanted though.
Tarlowb
Re: Filters?
Thanks for the quick reply!
I have seen a few images online of people putting one in line as you say, not sure if the were in addition to one further up or standalone. I have also heard that it was then restricting the flow.
If there is one in the tap I'll leave it alone, I just worried that I needed one and didn't have one, or had one and it needed changing.
