vfr400 nc30 type 6 decals needed
- Reactions:
- Bike owned: NC30 / 675SE
Re: vfr400 nc30 type 6 decals needed
spiderdog, I recently contacted image works regarding seed decals and got the following reply
"We can supply the lettering for this colour scheme, but pretty much all the rest of the design is painted.
The lettering set will cost £40 plus post.
We make them to order. Depending on the time of year, turnaround ranges from 1-2 weeks
Graham"
Hope that helps. Haven't ordered any yet.
Graham"
- Reactions:
spiderdog wrote:Hope you get to see this Causon. When Graham supplied the Decals to you what did you get if you dont mind me asking as I'm restoring back to original colour.Causon67 wrote:Try the image works
They did a full set of type two (seed) decals for £45
I spoke with graham on 0115 944 3111
Did you get the lettering and other decals as well? Red/Black triangles?
Thanks, it would be a great help.
Sorry it's a very late reply, I got the Honda on nose cone and red H piece, the Honda on the lowers and the vfr400r in white for the seat unit and the force v4 and the red triangles to sit on the mid panels, everything else is painted on the fairings
Pete
- JZH
- Reactions:
- Bike owned: RSCBRRVFVFRST
For future reference, in case it helps someone down the road, the OEM paint scheme being discussed in this thread is called "No.6" or "Type7". There is a lot of confusion about these two terms, unfortunately. See: http://www.vsource.org/VFR-RVF_files/Bvfr400r-mi.htm.
Ciao,
Ciao,
