quick action throttles
tom wood
Does anyone know where i can get one from. I've seen a few HRC ones on ebay for the cbr600rr, cbr100rr, do these fit?
- vfrman
- Bike owned: NC30, 1098s
Re: quick action throttles
Rick Oliver does one. He is around here somewhere.
NSR250 mc21 throttles will fit and give a shorter turn.
- Psychosomatic88
Do you need the throttle tube and the cables?Stickshift wrote:NSR250 mc21 throttles will fit and give a shorter turn.
Going on the internet is like owning a gun... Just point, click, then shit your pants waiting for the Police to turn up.
- RickOliver
I keep the genuine HRC/NSR ones in stock but being OE parts they cost around £50. Throttle movement is 60 degrees (1/6 turn)...
r.oliver(at)mtxnet.co.uk
- oliherst
I have one on my NC30. Found out after I bought a new open and close cable for the stock throttle then they wouldn't fit. Keep meaning to post the part number on here to find out what it's from, David Silvers website didn't know.
Spike16
so is it just the tube you need of the whole thing? and do you use the standard cable?
- Psychosomatic88
Spike many QA work in different ways in my expierence, and differ on bike. Some route the cabling a different way by means of different throttle cams, some are more and less sophisticated.
I suspect on the NSR one you need the throttle tube and cables, or modified stock ones. Im sure someone will quickly clarify :D
Spike16
yeh i mean on the nsr one?
if people are doing away with one of the throttle cables I assume that means you dont need both? (obviously) so why do manufacturers out both on (just a saftey thing?)
- Psychosomatic88
They are throttle open and throttle return cables, I suppose its to help with the MOT as in needing a cable to help close the throttle? maybe?
However I find it snaps shut faster/better without it :D
