Nc35 trouble starting and idleing
Mavirick
Bike owned: NC35
Post by Mavirick »
Hi all
Having some issues with my NC35
When the bike has been standing for a night of a few days i have a massive mission to get her started and if i do get her going she battles to idle and rev up.
Ive run out of options please help
MAV
Sent from my SM-N910F using Tapatalk
magg
Bike owned: VFR400
Re: Nc35 trouble starting and idleing
Post by magg »
Starts easy once warm?
RichardJ
Bike owned: NC30 type1 MC18 red MC18 blue
Post by RichardJ »
Carbs balanced, valves clearances checked?
Mavirick
Bike owned: NC35
Post by Mavirick »
Most of the time yes...valve and carbies are fine when she is still a bit coldish when you pop the the throttle revs drop and she dies
magg
Bike owned: VFR400
Post by magg »
They all need some warmup from cold.
Choke and vacuum tap working correctly.
Personally found that converting vacuum fuel tap to fully manual improved the startup if the bike had not been used for a few day. Think fuel evaporation and slow float bowl refill, as consequence of limited vacuum during cranking, may have been the issue.
Mavirick
Bike owned: NC35
Post by Mavirick »
Mag your manual tap from what bike is that or how did you convert it
magg
Bike owned: VFR400
Post by magg »
Used the guide in the HRC TT formula 3 setup doc from this site library. Rearranged the tap internals using the spring to keep diaphragm open and plugged the vacuum hose from the intake. Apologies for the lack of clarity, been a while since I did it.
Mavirick
Bike owned: NC35
Post by Mavirick »
Awesome thanx
Mavirick
Bike owned: NC35
Post by Mavirick »
Magg can you send me link please
magg
Bike owned: VFR400
Post by magg »
