Fitting hrc rear linkage
MARSHnc30
Re: Fitting hrc rear linkage
Post by MARSHnc30 »
Yeah that is the exact problem I'm having bike is completely off the ground on abba stand !! I will hopefully get back in the shed over the weekend (if I get permission) will try and get hold of Rick too !!
MARSHnc30
Post by MARSHnc30 »
I would put a pic up but can't work out how to :whistle:
Ok ive took it off the abba stand and there is clearance......well a fag paper of clearance lol. Im pretty sure this wasn't the case when i had it on my rvf so maybe the hole for the shock is bigger on the rvf as the swignarms are slightly different.
Honestly i dont onow if id be happy running it like this
MARSHnc30
Post by MARSHnc30 »
yeah that's what mine is like !!! Will have to ring Rick again and see what he says !! Surely it's not ment to be like that !! Just a bit gutted its cost me over £750 just for the shock and linkage !!!!
jpete41996
Bike owned: VFR 400
Post by jpete41996 »
I do not have an HRC linkage, but did buy a nitron shock/modified stock linkage from Rick and have no clearance probs on my VFR400. Since he adverts the nitron shock to suit his HRC linkage, Rick must know it works. Contact him for sure. He is a top bloke and will help ya out!
If i can wrench on cars, bikes should not be a problem, right?...
jpete41996
Bike owned: VFR 400
I did install my setup on an abba stand and there was no real rubbing problems during the install.
^^There wouldn't be if your using a stock linkage and shock
Swingarm
Bike owned: AR 125, NC30
Post by Swingarm »
I know this was a long time ago but was there a fix to this problem?
I.e. HRC linkage + non-stock shock = spring tight against swingarm hole?
