Vfr 400 forks
balen1
- Bike owned: Rvf 400
Vfr 400 forks
Hey guys. Servicing.my forks and having a bit of trouble working out how much oil goes back in. The Haynes manual specifies a different amount depending on the model. Not sure how to work out which model mine would be. Any help asap would be appreciated as I have to get it ready for track next Saturday thanks.
richyrd5
Re: Vfr 400 forks
Does yours have brass adjusters on the top or just large slits for a flathead screwdriver??if you have small brass adjusters then they are later type fork,ones with large slits are early type
demerdzhiev
- Bike owned: NC21
Re: Vfr 400 forks
Can anyone tell what are the specs for nc21 forks ?
balen1
Re: Vfr 400 forks
All.good guys worked it out. Only thing I'm curious about is that my spring aren't stock. Will they affect the amount of oil that should go back in
- JZH
- Bike owned: RSCBRRVFVFRST
Re: Vfr 400 forks
The NC24 and NC21 specs are listed in the back of the NC30 Haynes manual.demerdzhiev wrote:Can anyone tell what are the specs for nc21 forks ?
NC21:
10wt fork oil
Right fork 340cc
Left fork 345cc
-or-
Fork oil level 151mm (meaured from top of the stanchion tube with the spring removed and the fork fully compressed)
I always use fork oil level, rather than capacity.
Ciao,
demerdzhiev
- Bike owned: NC21
Re: Vfr 400 forks
i owe you one!
- JZH
Re: Vfr 400 forks
Rakia will do!
Having Bulgarian friends, I am quite familiar with the drink...
<hic>,
<hic>,
demerdzhiev
- Bike owned: NC21
Re: Vfr 400 forks
hahahahahahaa i didnt expect such an answer, u got it. i will be glad to trade some rakia for bike parts :D
