RVF Engine Build Project
Re: RVF Engine Build Project
Amazing rebuild, and a great write up!
Hope you get leak sorted.
Ian
Ian
- BB_158
- Bike owned: is half tidy
Awesome work Dave, we will have to go for a beer to celebrate your achievements.
Hopefully will you be whipping everyone's ass at Cadwell, eh?
My other ride is another 400, Woohoo!... Doh
BB_158 wrote:Awesome work Dave, we will have to go for a beer to celebrate your achievements.
He did mention you liked a nibble on the ear and a good whipping lad....
oh.....
On the track...yeah, got you :)
- micpec
Indeed as others said...nice write up, great stamina to push towards a final engine.
Is that a donut oil cooler from an nc23/cbr?
- DAC
- Bike owned: 89 NC30
Did the rear wheel conversion myself, by turning down the spindle a tad and then making some oversize washer pieces to locate against the wheel castings to prevent it slipping on the hub.davethetrucker wrote:Astounding attention to detail great work![]()
Did you do the rc36 rear wheel conversion or is that one of the ones done by a forum member from Northumberland a while back ?
Regards,
Dave.
RWB NC30
- DAC
Most of them are already here, 'cos I've been at it for ages in stages, but you are correct, I've not specifically detailed the QS. I'll get on the case, though it's a simple addition really.Yakama wrote:Excellent write up mate! It's guys like you that really keep these old bikes going!
Perhaps a write up on some of your other mods? Like the QS you made?
Regards,
Dave.
RWB NC30
- DAC
I think that's it Liam, though my data file is on the laptop in the lockup at the moment. I'll check and confirm.Yakama wrote:So assuming yours is a suzuka too, this is it compared to the NC30 F3 HRC gearbox (Everyhting is the same apart from the 1st gear I think
VFR400R NC30 % Drop
F3
15-41 2.733
18-38 2.111 22.76%
20-36 1.800 14.74%
22-35 1.591 11.62%
23-33 1.435 9.81%
24-32 1.333 7.07%
51.22%
Using CBR400RR NC29
HRC Suzuka apart from 1st Gear
14-41 2.929
18-38 2.111 27.91%
20-36 1.800 14.74%
22-35 1.591 11.62%
23-33 1.435 9.81%
24-32 1.333 7.07%
54.47%
Regards,
Dave
RWB NC30
- DAC
Thanks for all the comments guys, it's been a most rewarding process.micpec wrote:Indeed as others said...nice write up, great stamina to push towards a final engine.![]()
I think this particular donut was from a '600, but I ordered the bolt new from Honda.
I've lost count of the number of water pump covers I have modified over time.
And then ... the RVF water pump is different
Who knew
Regards,
Dave.
RWB NC30
wondering about the oil cooler
you have a water cooler and have drilled it out for a raditor too right.
Are you planning on running both simultaioniously?
- fourfingers
- Bike owned: NC30RK,NC35RR
Dave, very nice build and attention to detail.
Your pics of the oil cooler and filters have been very useful (ended up with a FZs600 cooler that does the trick)
I have just finished modding and installing your lower rad´s "twin brother" and it is massive. They both came from a set of bikes that belonged to Craig McLelland, I believe.
I did cut 4 rows on the top an added standard mounting points, but has been quite tricky to make it fit with the fairings.
Keep it up.
Keep it up.
