Can you see what it is yet
Re: Can you see what it is yet
Post by Evilchicken0 »
Top end time then.
Again practice fit the barrels - I immobilised the centre pistons
I used 1/4" extension bars to hold the outer pistons
.... to give me this
After this I slapped on the head and tightened it using low, medium and then full torque. So next I'll move to cam shafts
Morespeedvicar
Post by Morespeedvicar »
Ace pics dude, great to see it. I rebuilding my klr engine. What number three bond did you use?
hunter
Post by hunter »
Coming on nicely .
Hogdigerdy Dog
Bike owned: FZR400RR 3TJ, ZX9R fighter
Post by Hogdigerdy Dog »
ellow again
nice one boris, a good job well done ;)
Wotcha :)
Dropped the cams in ... So cam timing then ... couldn't work out why it didn't go in right, until I read back through the manual and dropped the exhaust cam in first :?
TDC on the flywheel lines up with the cases joint at the front of the engine, and the cams marks are vertical on exhaust and vertical +15% on the inlet
With the engine buttoned up I moved on and used the new scissor jack to get the engine in the frame. Usually I drop the bike on it's side work the engine in and stand it up but using this was actually easier
Time for a well earned curry I think :peace: :grin:
More stuff done today, clutch in, generator on, exhaust & radiator on, oil & coolant in. I spun it over on the starter (it didn't go bang) to get oil pressure.
To do - put the carbs on, top the oil up, change the left hand clip-on. Start the bugger.
1966baz
Post by 1966baz »
Looking good mate, nearly there ready for the summer.
Put the carbs and airbox on ... it runs :o :grin: :grin: :grin:
Woohoo
So after getting the bike to run I did a few small jobs, clean and set the chain, changed the brake pads for some EBC HH, I thwacked the lock stop boss around so the left bar doesn't trap your fingers.
Then I got onto the tail body panels, the left was a little scuffed but not to bad, I would have replaced them but I didn't see anything in reasonable knick. I decided to sort out the missing / broken bolt holes, the right hand one was worst so I cut a bit out of a scrap panel and let it in. The left just panel needed a bit moulded on.
Mot time and it passed. :)
