Low/high beam switch stuck
demerdzhiev
Bike owned: NC21
Post by demerdzhiev »
Couldnt find any thread on that, so my low beam/high beam switch is stuck on high beam and cant switch onto low, also the passing button doesnt work? disassembling it and spraying it with contact spray? any advice
magg
Bike owned: VFR400
Re: Low/high beam switch stuck
Post by magg »
disassembling it and spraying it with contact spray? Yes.
Post by Neosophist »
demerdzhiev wrote:Couldnt find any thread on that, so my low beam/high beam switch is stuck on high beam and cant switch onto low, also the passing button doesnt work? disassembling it and spraying it with contact spray? any advice
nc21 uses only 1 h4 bulb so it shouldnt melt the switch unless you have put an over-wattage bulb in, if its a normal h4 then as magg as already pointed out its probably just crap in the switch so a straip and clean should sort it.
demerdzhiev
Bike owned: NC21
fixed* there was this little plate in the switch (it's pushing the guide for the slider) that needed to be bent in its original position, everything lubricated and now works perfect.
Swingarm
Bike owned: AR 125, NC30
Post by Swingarm »
Anyone know where to get a replacement headlight switch (on right bar) for a VFR400 L?
I looked at Wemoto but they don't seem to have it and David Silver's parts list is an enigma to me (if I get stuck I'll call though...)
And some aftermarket red button jobs look a bit sloppy
Any pointers appreciated
s
