1990 GK76A Race Kit
- Reactions:
- Reactions:
Re: 1990 GK76A Race Kit
Some visuals incase your run across some kit parts for the GK76
1990 Kit CDI +500rpm. Not sure what else it does. Not sure if would still run lights etc.
1992 Kit CDI No info on it other than it should not be used with 1993-on models.
Kit Chin radiator and hoses (missing bottom mounting bracket)
Kit coolant intlet
kit headers
kit midpipe and muffler
Kit coolant intlet
kit headers
- Reactions:
- Bike owned: Kawasaki
Nice to see....
- Reactions:
- Bike owned: 6 gk76a's, nc29
The kit cdi can be used with all models but 93on requires timing rotor from pre93
- Reactions:
- Bike owned: GSXR400 GK76
- Reactions:
- Reactions:
Yep, looks like the Autorimessa kit headers to me. Where did you pick it up at?
- Reactions:
They came fitted to the bike, I have put an original exhaust back on as the bike would not run properly. I have now found out it was a problem with the carbs, but I can't be bothered to refit the race system.rgvsp wrote:Yep, looks like the Autorimessa kit headers to me. Where did you pick it up at?
- Reactions:
Sorry for gravedigging,but apparently i just bought a race kit CDI
The label reads 32900-35D00. Does anyone know what the differences with a normal one are?
- Reactions:
At a minimum it should raise rev limit by 500rpm. If yours is a road bike I'd be curious if it runs lights, blinkers etc.
