vfr400 nc21 problem
cjford23
- One Hit Wonder
vfr400 nc21 problem
Hi all new to forum so hi, just wondering if I can fit a nc24 engine to a nc21, and what's involved ive read that alls different is a sensor on engine, but looms different to accommodate it, mine has the crank sensor, but I cant find a running nc21 engine anywhere for the life off me, my piston is missing valve gone, barrel battered god know what previous owner done to it, I have bought as project so need know what's involved in the process of putting nc24 engine in ?? Cheers all
startline
Re: vfr400 nc21 problem
Still want an nc21 engine, I have one
slavokMS
- Bike owned: Rvf400, VFR400
To install the motor from nc24, you need to install your crankshaft sensors nc21 and overrunning clutch assembly with nc21.
or just fit the NC24 wiring loom....slavokMS wrote:To install the motor from nc24, you need to install your crankshaft sensors nc21 and overrunning clutch assembly with nc21.
slavokMS
Yes you can! BUT! there is an old engine it is easier to remove the necessary parts and install the new NC24Neosophist wrote:or just fit the NC24 wiring loom....slavokMS wrote:To install the motor from nc24, you need to install your crankshaft sensors nc21 and overrunning clutch assembly with nc21.
timing is slightly different on nc24 though so perhaps its worth to put the nc24 ignition box?
not sure
not sure
richyrd5
seems better to take up startlines offer and put the 21 motor in!!
