Fairing fittings
redbandit12
- Bike owned: FZR400 3EN2
Fairing fittings
When fitting the lower fairings, the left side has the choke mechanism to space it from the frame. What is used on the right hand side ?
willandrip
Re: Fairing fittings
Have you got the triangle shaped plastic scoops that deflect air from the fairing ducts to the motor ?
redbandit12
Yes, they are on. Is there some sort of spacer between the fairing and the scoop or does it just tighten up against it ?
willandrip
On my bikes they just fit against the scoop.
I cannot see anything else on the parts fiche.
redbandit12
Yep, got it now thanks, just nips up against the scoop. Thought there was more of a gap.
Cheers Will
Cheers Will
