Anyone Running a dynojet kit with standard airbox?
				claig03
has anyone got the dynojet kit in their 3tj with a standard airbox and muffler? if so what main jet are you running.
can anyone help
						can anyone help
Re: Anyone Running a dynojet kit with standard airbox?
Dynojets can be weird to set up because the carb bodies have to be drilled. If the drilling is a little off the needles don't drop into the jets exactly right.
If your running standard it's probably quicker to get some secondhand carbs clean them up and set them to your engine.
