35 swingarm on 30
richyrd5
35 swingarm on 30
Is it worth the hassle?i can get a polished one and do like the brembo caliper conversion...also whats the crack with putting a 35 sprocket carrier on a 30!??thanks
- skinnydog0_0
- Bike owned: Penny Farthing
Re: 35 swingarm on 30
They are not interchangable - the 30 is slightly narrower across the pivot than the 35.
Sprocket carriers are okay to swap though.
hunter
You could probably fit one using spacers.
202 and 208 springs to mind but the rvf arm is narrower.
- speedy231278
richyrd5
ah cheers chaps for that,not really worth the hassle just for a caliper conversion..although it wouldnt be hard to do.as john said 2 spacers!,what is better about 35 sprocket carrier than a 30 one jeff?
- skinnydog0_0
Yer i got the dims back to front.
I have no idea if the 35 sprocket carrier is better than the 30 i think they are the same other than the 30's one is black and the 35's is gold.
I am sure i'll be corrected if there is a difference :)
They have different part numbers but i have a 30 one on my 35 swingarm and hub and it seems to fit bang on.
richyrd5
Cheers chap.that about figures.its gold!!.wondered what was different!!thanks
