RE: Clearance issues with fork tops raised above yoke
marty400
Hiya All,
hhmmmm... thinking about CBR600f Uppers on a NC29.
However, longer than the 400 fork tubes, so will need to stick out a bit over the yoke....
How high can the fork tops go above the yokes, before clearance issues with the Screen brace at full lock etc?
I measured 30mm clearance at full lock.... it that to tight?
hope you can advise
Regards
Martin
hope you can advise
Regards
Martin
marty400
Re: RE: Clearance issues with fork tops raised above yoke
Can the cbr600 fork tubes be cut down, and everything still fit internally?
What are the internal unit lengths though like, compared to std dampening rods etc.
Martin
Ps: Fork tube lengths found:
Nc29 fork tubes are approx 6cm shorter!
(What about the the fork lowers as well?!)
Cbr6:
Fork Tube Honda CBR 600 F3 95-98, 1 piece, Diameter 41mm, Length 633mm, OEM Part Number 51410MAL601
Nc29:
BRAND NEW "ABE" FORK STANCHION FOR HONDA CBR400RR GUL ARM.
NC29.1990-1994.LENGTH- 572mm,DIAMETER-41mm.
Nc30:
533mm from forum post
Martin
Cbr6:
Nc29:
Nc30:
