NC35 linkage indentification
benny
Bike owned: NC30 (track), ZX-9R (road)
Re: NC35 linkage indentification
Post by benny »
Drunkn Munky wrote:Dont think you can, i'll measure one for you when i go out to the workshop
Anything Tony? cheers
DM104 for the road race team.
Sorry forgot :oops: i'll be going back out after dinner so i'll get it then
Rvf is 110mm
benny
Post by benny »
Drunkn Munky wrote:Rvf is 110mm
Is that from the center of each hole?
Yep
richyrd5
Regular Member
Post by richyrd5 »
Nice one tony
benny
Post by benny »
Thankyou
RickOliver
Post by RickOliver »
The NC30, NC35 and `RO jackup` bottom links measure 113mm, 109mm and 105mm respectively between centres
The RVF tri link has a needle roller bearing at the point where the shock mounts, the VFR version has a metal/rubber/metal non-articulated bush.
Honda also simplified the manufacturing process for the RVF tri link - all the roller bearings on both versions are 24mm o/d, on the VFR the bearing housings are counterbored and use 17 x 27 x 5 seals, on the RVF the housings are bored straight through and use seals with the same o/d as the bearings (i.e. 17 x 24 x 5).
Converting from VFR to RVF type shock mount bearing is not just a simple `press out/press in` operation - the o/d of the VFR`s bush is only 20mm so after removing it the housing has to be bored (parallel, concentric and accurately!) to 24mm. The needle roller bearing which goes in there is a Honda bespoke 17 x 24 x 17 size, it is not commercially available and costs about £18 from Mr H...
Rick
richyrd5
Regular Member
Post by richyrd5 »
A mine of info as usual!!!
benny
Post by benny »
Thanks for the detailed reply Rick,
So if I'm fitting the NC35 linkage to my NC30 so I need the NC35 or 30 tri bit?
