Starting NC29 for the first time in 4 years
franna16
Hey Guys.
So I think it's time I Get my NC29 Racebike running again.
This was my dads bike but he passed away about 5 years ago and since then the bike has just been standing there.
The bike was very fast and did well in our Powersport class.
What would I need to do?
1. Oil change.
2. Carb clean
3. Maybe oil filter change.
What else? I am charging the battery as we speak.
1. Oil change.
2. Carb clean
- Davez29
- Bike owned: NC29 forever
Re: Starting NC29 for the first time in 4 years
I would try and pump some new oil through without starting the bike deffo replace the oil filter, also put a small amount down the bores. Clean carbs, check all hose. Change brake fluid as you would like to stop as well as go. The list is endless really. Make sure you have a good battery to eliminate any voltage problems and while your at it, change all plugs.
Good luck.
Good luck.
matt69
- Bike owned: NC29, CBR6F2
definitely new plugs and check throttle cable returns properly as well
