When fitting R&G frame/fairing protectors...
manicguitarist
- Bike owned: RVF400 (NC35)
...the non fairing modification type...
Do take care with the routing of the cable from the sidestand...
I managed to crush mine ...
The bike worked but the side stand light wouldn't go out.
On investigation one wire had its insulation cut and was shorting out against the frame.
Insulating heat shrink applied...all is well.
Re: When fitting R&G frame/fairing protectors...
i take it this is to an RVF then :)
manicguitarist
Yes it is. Curious though - how did you know?
Loudandproud205
- Bike owned: VFR400R3 NC30 NSR125R JC20
NC30 doesn't have a kick stand light, or if it does mine doesn't work.
lukemillar
and it is written under his username on the left!
manicguitarist
Oh yeah.
D'uh!
D'uh!
