nc29 running issues
ChowderV4
nc29 running issues
im fixing up a cbr for my brother to race at thruxton in october but having a bit of a nightmare with it running.
-I have cleaned the carbs, float bowls were clean when i took them apart
-running standard jetting and set up
-new plugs
-nipped 5mm off each ht lead so fresh lead showing
-new fuel filter
It starts and idles ok, sometimes it can get a little lumpy idling but its intermittent. sometimes when riding it will pull nicely up to 9.5k then just bog and feel really flat, as if its dropping a cylinder. sometimes it will pull through but it will really struggle and lurch as if its cutting in and out of 4 to 3 cylinders.
Now today i rode it, it was riding as above for first half an hour, but then it started pulling clean through if you accelerated from low revs.
occasionally it will drop to 3 cylinders at very low riding speeds then pick up 4 at about 4/5k revs
Any ideas peeps
-new plugs
-new fuel filter
Any ideas peeps
tanuki
Re: nc29 running issues
Coil breaking down?
ChowderV4
possibly , ive got a few spares kicking around, so i'll give it a gotanuki wrote:Coil breaking down?
tanuki
Check the wiring where they plug into the loom under the air box as well
ChowderV4
i fitted a new set of coils, worked good for the first ride pulled through, still a bit hesitant in 4th gear up after 10k revs.
but then next ride it was back to normal, i've just cleaned out the carbs again, checked all the diaphrams and everything was all ok.
It rode different again once i put it back together.
Now has a tiny flat spot at 8k then pulls through, will rev to redline most times in first 3 gears, but in 4th gear upwards once it hits 10k it starts hesitating feeling like its cutting in an out on once cylinder, either fueling or spark but ive checked all this over about 6 times now. at a loss
tanuki
I think its new loom time, they are not exspensive and will take you about a day to fit.
God knows though, could be anything from CDI - TPS
Good luck
Good luck
ChowderV4
Yeah I've got no problem fitting a loom, made my race loom for my zxr.
Gimly56
- Bike owned: NC29 CBR400RR
Sticky valve??? I had the same issue on a GSXR400 of mine and it had a valve that was sticking according to the mechanic...
ChowderV4
that was my next direction, checking compression etc
no need anymore as my brother got tired of it not being fixed so bought another cbr 400
so now i can give the shit one back to my mate aha
Gimly56
Haha problem solved then!!
