CBR400RR Ignition fuse blowing constantly!
tanuki
Re: CBR400RR Ignition fuse blowing constantly!
sorry just confirm for me its the fuse in the fuse box blowing?
Gimly56
- Bike owned: NC29 CBR400RR
Yes its in the main fuse box.
Gimly56
Gimly56
OK PEOPLE, FINALLY GOT TO THE BOTTOM OF THIS!!!!
It was the fuel pump wiring causing the issue. Disconnected the fuel pump and no worries. So now I just have to figure out where exactly to wire the fuel pump into the loom. I'll just play 'trial and error' until I get it going. At least I have finally figure out which part of the bike is causing the issue!!!!
Thanks everyone for all their help and ideas.
tanuki
IIRC the fuel pump isnt hard wired into the loom its one of the plugs that sits in a little 'rack' under the seat area its a small black one I think.....I would replace the fuel pump they are cheap as chips as they are made by Mitsibushi and cover a variety of models I fitted one from a ZXR750 I think and all I had to do was replace the plug.
Gimly56
Yeah it plugs in between the tank and seat in that little harness....but from there it does hook into the main loom...tanuki wrote:IIRC the fuel pump isnt hard wired into the loom its one of the plugs that sits in a little 'rack' under the seat area its a small black one I think.....I would replace the fuel pump they are cheap as chips as they are made by Mitsibushi and cover a variety of models I fitted one from a ZXR750 I think and all I had to do was replace the plug.
It's a new fuel pump so I was kinda hoping I didn't have to replace it? We'll see. I'll test it straight off the battery tomorrow. I'm pretty sure it's just a bad connection in the wiring somewhere.
