NC29 Poss Gearbox Failure any advice
Nuttykermit
Hi all first post since acquiring an NC29, had most of the usual issues Carb, Rectifier, Fork Seals mostly rectified by forum information.
So the problem, on pulling away from a roundabout opened up the throttle in second at about 11k rpm massive bang, loss of power. Clutched in but bike won't change up or down gear and on clutch release bike sounds like a bag of spanners.
I coast to side of road, the bike can be revved normally clutch in no massive dramas. However can't let go do clutch or it sounds like hell is breaking loose from the internals of my bike. So shut her down on inspection bike is leaking oil appears to be near the front sprocket, checked oil levels this morning all good. The chain is tight on top but loose on bottom was also fine this morning. That's where I'm at.
Now stood beside bike waiting for the AA to come and cart away what must be a very poorly bike.
Anyone with any experience on what I have said your thoughts would be greatly appreciated.
Thank god for phones not only to call the breakdown but can post on the forum while I wait.
1990 NC29 RRL Standard apart from 4-1 exhaust
Nutty
Nutty
- Davez29
- Bike owned: NC29 forever
Re: NC29 Poss Gearbox Failure any advice
Output shaft bearing gone kaput?
Nuttykermit
Is this a big job, gonna get dropped down the local gatage , unfortunately every good day is outweighed by ten bad days.
Nuttykermit
Just for all how may have looked, the garage has confirmed it was an output shaft bearing failure, the bearing have disappeared into the gear box, the input and out put shafts are misaligned, due to the RPM this happened at god know what condition the gears or selector fork are in too.
So unfortunately i think that its time to say good bye to this one and move on
Thanks for the advice and it was spot on
Nutty
Nutty
dunkenb
