Nc30 sprocket seal leak
steve92
Hi, i've got a leak at my sprocket, i pulled the seal out and the shaft looks to be worn. Can the piece that slides over the splines be removed without splitting the engine? I know the engine should be split to fit the new seal but was thinking is it possible to cut the lip on the seal off and fit it and possibly put a sealant on the outside edge to keep it in place, just a thought.
- speedy231278
Re: Nc30 sprocket seal leak
I don't think that's a good idea. I assume the fairly sizeable step in the seal is to prevent the crankcase pressure from blowing the seal out. Granted, splitting the cases is going to be a very long and tedious job (and expensive if you pay to have it done), but I'd not trust some gasket sealer to hold a seal in place. All it's really good for is taking up small imperfections between two surfaces that are held together by something more solid.
- vfrman
- Bike owned: NC30, 1098s
Unfortunately I agree with speedy. You really need to split the cases to fix this problem. While you are in there, you might as well check the piston rings and bearings.
steve92
Going to pull the engine out tonight and split it and do it properly, I kind of knew that was the only way to go. I was hoping there might of been an easy way out.
Thanks for the replys.
not really an easy way to do it,
While your there you might as well replace the gearchanger shaft seal and clutch rod seals too as they dont cost a lot but cost a lot to replace.
Might be also worth as mentioned above getting a bit of plastigauge adn checking everythings in spec.
- speedy231278
Why is it unfortunate to agree with me? I dunno, you could give someone a complex....vfrman wrote:Unfortunately I agree with speedy. You really need to split the cases to fix this problem. While you are in there, you might as well check the piston rings and bearings.
- vfrman
Lol. Unfortunate because he has to split the cases.
