NC35 CARBS - INFORMATION PLEASE
- RickOliver
Re: NC35 CARBS - INFORMATION PLEASE
So - CMS and the first thread you quote say wider spaced holes in the front, the second quote and your thread say wider at the rear.
On balance I`m inclined to go with wider at the front for now but I`d still welcome a definitive answer...
Rick
Rick
- Speedy
- Bike owned: RVF400RR, ER6n
Hope this helps. Cylinders 2&4 (front) have the wider spaced tubes.
Taken from my own RVF.
CybaHag
My apologies for butting in here but I need to ask a question.
I was cleaning my NC30 carbs a short while ago and removed the emulsion tubes. I noticed that 3 of the tubes had the 3 hole setup (similar or the same as the pic above) and the remaining tube only had a 2 hole setup. Is this normal and if so what the purpose of this and what difference would it make if I have all four of the same tubes with same patterns put in.
- speedy231278
You're right.... so I even got that wrong! Would the definitive answer not be for someone to buy the type that's still available and then match it to the parts diagram?RickOliver wrote:So - CMS and the first thread you quote say wider spaced holes in the front, the second quote and your thread say wider at the rear.
Rick
viewtopic.php?f=24&t=14524CybaHag wrote:My apologies for butting in here but I need to ask a question.
cmsnl do not list the front tubes as in stock.. anymore, but buying just the rear would confirm it for sure.speedy231278 wrote:According to the pics on CMS' website, the tubes with the wider spacing are the fronts. The hole patterns are different in the pics for the front and rear tubes.
This thread on here agrees: viewtopic.php?f=24&t=12131
So does this one: http://400greybike.com/forum/viewtopic.php?f=24&t=46158
My carb thread seems to disagree, but I'm not infallible and they were secondhand carbs so a previous owner may have mixed them up, or I may have mis-identified the particular carb as I seem to have used different carbs to show different parts. So, I'll discount that one....
