Indicator issue
Stitch - NC30
Indicator issue
Hi Guys,
Having a slight issue, the front indicator on the front n/s was not working when I got the bike, so after removing the fairing etc I hooked up some budget new indicators.
The front o/s works fine, but the front n/s is flashing double time, none of the bulbs are led or alike - so not sure where my problem lies
Any ideas?
Cheers,
Richard
Any ideas?
Cheers,
Richard
Why when I take something apart and rebuild it; Why do I have so many spare nuts and bolts?
- speedy231278
Re: Indicator issue
I'm pretty sure the flash rate is determined by the resistance of the lamps attached to the circuit. If both are actually flashing on the same side and doing so very quickly, I would suspect one or both are the wrong wattage.
Stitch - NC30
Re: Indicator issue
Cheers,
Must admit I didn't check the wattage of the bulbs (just that they were bulbs) - had a quick search but from what I can see Jap bikes "should" have 15 Watt bulbs and UK bikes 23 Watt - assuming the relay is standard.
Will report back,
Regards,
Richard
Will report back,
Regards,
Richard
