FZR RRSP 3TJ7
- Bike owned: MC22, 3TJ1
Re: FZR RRSP 3Tj7
Thanks Dobbsic, that would be great.
If you have an inclinometer a rough value for the carb angle would be good too. Assuming you have standardish tyre sizes and suspension length.
Carb seal kits in viton & other parts
https://litetek.co
https://litetek.co
Re: FZR RRSP 3Tj7
Here is a good thread showing how the carb angle on the bench may be achieved.
http://fzr250.com/viewtopic.php?t=1487
Re: FZR RRSP 3Tj7
Yes, I have seen that one. I want to do mine on the bench too, but I don't know if the 400 carbs sit at the same angle as a 250.
cheers
cheers
https://litetek.co
https://litetek.co
Re: FZR RRSP 3Tj7
Pics. show 3EN1/3EN2 carbs.
These have no cast in line central to the bowls; therefore the MIKUNI line is the only point of reference.
Infact only one pair in the bank have the MIKUNI line clearly cast.
I expect these to be the same body as the 3TJ; they are identified as 3EN10 in the supplement but bare no physical
numbers.
The setting for the 3EN series lists the fuel height as 24.8 mm ( I would expect the difference in height is because the 3TJ has a more sloping engine angle.)
numbers.
Re: FZR RRSP 3Tj7
Good work Willandrip. Where did you get the info for the 3EN1?
It seems there is just not much available for anything other than 1WGs.
https://litetek.co
https://litetek.co
Re: FZR RRSP 3Tj7
I sent for the 3EN2 supplement from Webike in Japan.
http://japan.webike.net/ps/#!p.m=858&p.c=9900&p.sk=1
Re: FZR RRSP 3Tj7
Interesting readiing, in other news the bike is alive and kicking! as a last ditch attempt i got the carbs that i bought for spares back out, gave em a quick clean to get the worst of the corrosion and rust out of them, replaced the parts i pillaged for the so called good carbs and bingo off she went. fucking chuffed as a chuffed thing
Its firing on all 4 which im a little confused about as one of the HT leads still doesn't give any resistance reading and another one gives a lower reading than the other 2 but it works so im claiming that as a victory. I dont feel bad about splashing out on the dyna coils either as i put the OEM coils and leads back on and it wouldnt start.
- Tim400GB
Re: FZR RRSP 3Tj7
Happy days mate. Now you can work on the other carbs in your own time happy in the thought she's a runner.
Re: FZR RRSP 3TJ7
Great news. Take it for a ride and let us know how it runs.
I know a place where you can get a carb kit!
https://litetek.co
https://litetek.co
Re: FZR RRSP 3TJ7
This bike just doesn't like me, its been running all week so booked a MOT for this afternoon and this morning im back to square one with it refusing to start.
Ebay tonight 8pm start if anyones interested, 99p start
