Lumpy idle NC30
dobbslc
Re: Lumpy idle NC30
I had similar on a GSXR once and turning the pilots out a bit sorted it out.
Also check the chokes are all closing correctly.
- GeeTee
- Bike owned: NC30 & GSXR750K4
Re: Lumpy idle NC30
video is marked as private - other one viewed ok?
- jpete41996
- Bike owned: VFR 400
Re: Lumpy idle NC30
yep, i cannot see either! would like to as i had some of the same problems and want a comparison.GeeTee wrote:video is marked as private - other one viewed ok?
If i can wrench on cars, bikes should not be a problem, right?...
Stoozak
richyrd5
Re: Lumpy idle NC30
sounds fine to me..
Re: Lumpy idle NC30
it looks like the revs are dropping down below the set idle speed, this usually means the bike is too rich.
Turn your pilot screws in, 2.0 turns out from fully in is enough.
Stoozak
Re: Lumpy idle NC30
hmmm, I had a flat spot on immediate acceleration if i blipped the throttle. It sorted bogged down for a fraction of a second (from idle) then picked up.
That's why i turned the screws out a smidge. Should I have turned them in instead?
lillywhite23
- Bike owned: cbr125rs nc30 type one
Re: Lumpy idle NC30
vavle clearances and maybe the battery is low as i had the same problems.
Stoozak
Re: Lumpy idle NC30
Battery charged and valve clearances checked.... :/
lillywhite23
Re: Lumpy idle NC30
You may have to get it dynoed and tuned
