Engine Removal Problem!
chrishs
- Bike owned: '90 NC30
Re: Engine Removal Problem!
Remove the bolt and hammer a socket on to the adjuster bolt, ive had to do this recently
chrishs
Do you know what size it was? I hammered on a 20mm socket, but it just span.
Try a smaller one
I think it was an imperial size, i'll check tomorrow as the adjuster is still stuck in the socket
chrishs
I did think that was a silly question.. oops!
Great, thanks.
Great, thanks.
chrishs
Tried 13/16's spark plug socket earlier, tighter than the 20mm, but it still span on the adjuster! Would it be worth trying to weld something onto it?
RVF400RR
I can't get the bolt shown in this picture out
The castle nut is off.
The 6mm hex hole has been destroyed using an impact gun in an attempt to remove the bolt with the adjusting bolt
I have tried hammering the bolt from the left hand side, but it will not budge?
Any suggestions greatly appreciated.
- iDemonix
- Bike owned: '92 NC30
Just to check, have you tried jacking the engine up a tiny bit to relieve some stress on the bolt?
RVF400RR
Yes, I've had a jack under the engine.iDemonix wrote:Just to check, have you tried jacking the engine up a tiny bit to relieve some stress on the bolt?
I've tried knocking the bolt out with the jack / engine raised and lowered but it will not move
The bike is now on its side .....
I had one like this, nothing shifted it and ended up cutting the bolt to remove the engine. You then have to remove the remainder of the bolt from the engine.RVF400RR wrote:I can't get the bolt shown in this picture out.
The 6mm hex hole has been destroyed using an impact gun in an attempt to remove the bolt with the adjusting bolt![]()
