HELLP NC23 k-convershion fairing set
bettsyboo
Hi iv got a nc23 and iv just brought well i say just brought i brought it 3 month ago and it turned up last week
k-convershion fairing set !!!!
tock me an my dad two days to fit the seat unit but is on there now and looks good
i just dont know were to start with the front cowl.
i have put it on quickley but looks like the clocks hit and the light hit the standered bracket.
has any one fitted a k-conversions kit to the nc23 or similar what did you have to do as im gettin no help from the k-conversions
thank you
thank you
gromit
Re: HELLP NC23 k-convershion fairing set
Hi Mate, Im pretty new to the site, a K conversion ?, I take it that its a upgrade fairing to make the bike look a bit more modern, if thats the case, it should be a direct fit either that or the company who supplied the fairings should supply the brackets to support the fairing, another thing I would think of looking at is the clocks and headlight bracket, you said they hit the front cowl, are the clocks mounted on the standard bracket, has the bike ever been down the road, the front subframe could be slightly bent as a result of a smack at some point, can you supply any pictures to go with your thread then we can all have a look and advise from there.
bettsyboo
yer the fairing makes it look like a new rr.
is ment to be a body kit but the fit is rubbish will look spot on when it done though
like i said seat unit took 2 days to fit that how good the fit is! lol
they did supply brackets but there not right ill take some pics at the weekend when i have a go at fitting it iv only hade a quick go so far like 5 mins
so ill see what comes of the weekend
- superlite
- Bike owned: TLS, LB80 x 2
These imported fairings generally take a little bit of 'tweaking' to get them to fit. Search any of the graphics and style sections for more info on fitment. If you're up to the task, it's just a matter of time and some elbow grease. Not sure if anyone has fitted this style, but there's plenty of standard shape K Conversions kicking about the forum (which also needed some work to fit).
I'm sure someone will have some more specific info, but a few pics could help your cause.
'Take it to the Back'
tanuki
needed some work to fit is an understatment LOL
scratchin
hi mate this fairing is a pain to fit first of all do you have the mounting brackets? on my bike i had to cut the clock bracket and move the clocks slightly nearer by making a couple of small brackets and also move the brake fluid resovoir slightly send me your email and i will try to get some pics for you with what i did(cant seem to post pics on the site)
cheers Tony
cheers Tony
gromit
sounds like its a job for the Dremel
