NC30 Rear Hub Collar
I bought my NC30 in basket case condition. When rebuilding the rear hub with new bearings etc, I cannot find the spacer/collar that sits into the seal and hub before the sprocket carrier fits, can anyone help, or supply a part number ? Cheers.
- Bike owned: 1990 nc30
Re: NC30 Rear Hub Collar
Try here http://www.cmsnl.com/honda-vfr400_model1258/partslist/
Here the swing arm schematic http://www.cmsnl.com/honda-vfr400_model1258/partslist/
If you can't buy one, post up a drawing with dimensions and I'll see if I can make one ?
Thanks for your replies, I will check out cms for replacement part. Thanks for offering to make a new part, but the problem is that I don't know the correct size i.e. not sure exactly where the hub sits....if that makes any sense ??
