cbr 400rr splutters above 6000rpm help
Swilki
- Bike owned: NC23, RSV Mille
Re: cbr 400rr splutters above 6000rpm help
Nc23 doesn't have a TPS so that doesn't help you..
Remove the carbs, remove the float chamber covers, unscrew the jets, blow compressed air through all the holes in them to clean them out, put back together, drain fuel tank and put new petrol in tank. That should help your running problem
