Disaster strikes
- Bike owned: Cagiva Mito, FZR 4003TJ
Re: Disaster strikes
Got some plastex ready for it.
Must have been you I seen sneaking out the back gate whilst trying to get your leathers on and jump on to a black FZR ( they're faster in black too
Sounds like it
She's taken shape over the weekend
just off out for a quick shakedown. I'll get some pics today if time allows and show you all what I've been doing for the last 3 months!
Ta ta for now and thanks for all your help
Wow forgot how well these bikes handle, borrowed a mates R6 a few times and it's quick but for sheer fun you can't beat a FZR 400! Everything seems fine except for a little fluid on right side of swing arm not sure if this is a little bit of oil from overflow pipe as a little was coming out when I changed the oil or brake fluid from reservoir (can't remember putting in the rubber part). Back brake isn't brilliant either so it could even be from m/c?
Apart from that she just needs MOT.
Bodywork needs a bit of attention in the future but will do for now
- Bike owned: FZR400RR
Whenever I get fluid on the swingarm (right side) its normally from the overflow on the coolant reserve, or the top to it has slipped off slightly (or a little loose).
Tends to happen on heavy lean angles occasionally, or if you've topped up the reservoir tad too much
Get you with your gold forks
Looking good
Looking good
