nc30-35 linkage
nc30-35 linkage
Ive the 35 linkage on my 30,does this raise the ride height,or is it taller with the 30 one on.tia.
- bikemonkey
Re: nc30-35 linkage
It raises the rear
Re: nc30-35 linkage
Thats wat i thought,but it sits pretty low,god knows wat it was like with the 30 linkage in!cheers tho chap
- Bike owned: '89 NC30
Re: nc30-35 linkage
I just did mine and the ride height at the rear (measured form ground to the upper tab on the plastic coolant reservoir) went from 690mm (tired old shock and std NC30 linkage) to 720mm (rebuilt shock and shortened linkage)
Re: nc30-35 linkage
Wow,best i get the preload spanner out.!!
Re: nc30-35 linkage
Check that your eccentric hub is not upside down too, this will lower the ride height quite dramatically.
