Can you see what it is yet
Morespeedvicar
Re: Can you see what it is yet
Post by Morespeedvicar »
Looks good that dude.
willandrip
Post by willandrip »
This topic required a bump and an update from Boris ! ;)
Post by Evilchicken0 »
I polished it a bit last night.
I had just oiled, put the top camchain guide on and fitted the tensioner to the 660.
chris6409
Post by chris6409 »
Evilchicken0 wrote:Just to take stock then
Image Image Image
Image Image
so I'm kinda onto the plastics, time to choose
Now a little warning: I just kinda knicked myself getting some stickers off the tail fairings, the 3TJ red is almost an exact match for blood ... the unoxygenated type from my thumb anyway ... careful with those razor blades
I see youve got lots of fairing there il love a top fairing and a chain guide
I thought your bike had a top fairing ?
chris6409
Post by chris6409 »
Evilchicken0 wrote:Cold huh and the days are short
I've been on the lookout for some downpipes since I got this bike so when a rusty set turned up on the bay I bit the bullet and bought them.
Image Image
The first job was to get the worst of the rust off them, I used a brass wheel on a slow drill and then gave them a coat of rust killer.
Image Image
The next weekend I used a fine grit paper with my Mouse palm sander
Image Image
And another coat of rust killer
Image Image
I missed the light or it was raining so I had to wait another week before I painted them
Image Image
I't not the best set in the world but they'll at least be servicable.
Surely there is a hero who could copy the downpipes in stainless and cut and weld the exup onto them to make new forever shiney 3tj downpipes :D
chris6409
Post by chris6409 »
About the tank rust ive got abit of minor rust in mine is it worth getting the acid out
If you have the acid then maybe - depending on how much there is. Otherwise probably not.
The 3TJ tank has a seam on the bottom so theres a bit on each side that doesn't drain when the tank's on the bike. If water gets in it sits in that bit because it's heavier than petrol, and rusts it. Make sure your tank dosen't have any water in - use a torch and see if there's anything in it.
chris6409
Post by chris6409 »
There the smallest amount of liquid in it but it hums of petrol ive tryed to get the last out but like you said its in a place to hard to reach i might try lowering a long pieace of rag in to soak it up
It's a bugger innit :grin:
Use a long piece so you don't drop it into the tank like I did. Or you can stick a hair dryer in the top of the tank
