Replace HT leads?
NC35!
Replace HT leads?
Hi there,
Does anyone have a guide or some tips for renewing the HT cables for the spark plugs please? A couple of mine ae looking decidely poor and I'd like to renew them - they are almost 15 years old now after all!
Thanks.
Thanks.
Simon_Ed
Re: Replace HT leads?
ring up your local honda dealer and order them?
NC35!
At £100 give or take for a new set of four, or £2 give or take for three metres of cable - no competition there I'm afraid!Simon_Ed wrote:ring up your local honda dealer and order them?
Simon_Ed
what about 2nd hand ones? If you get them made up make sure they're identical length
GF Racing
Assuming NC35 or NC30 - I have loads of good S/H tested original Honda ignition leads for sale @ £8 each.
UK delivery - £4 for a set.
Or new correct grade copper cored ignition lead in stock - you will need to resolder the plug ends on the Honda V4 family.
Paypal is easiest as per emai below.
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
- RickOliver
These are easy to make -
Copper cored lead into NGK SD05FM plug caps fitted with 32mm blanking grommets (held in place by O-rings above and below) to seal the plug wells
katana
Why can't you use silicon leads?
NC35!
That's the trick I guess! How do I separate the old leads from the original caps in the first place?France & Li Asia Tdg wrote:Or new correct grade copper cored ignition lead in stock - you will need to resolder the plug ends on the Honda V4 family.
NC35!
Has no-one done this?
- hannakournikova
Rick O obv has, why not drop him a mail?
