Brake Bleeding Help Please!
superlite
Bike owned: TLS, LB80 x 2
Re: Brake Bleeding Help Please!
Post by superlite »
A little trick that I find useful is to remove the brake lever and use a drift directly on the master cylinder piston (instead of the lever) - works a treat.
'Take it to the Back'
Jon
Post by Jon »
Get a DOUBLE BANJO BOLT BLEED NIPPLE, replace the banjo bolt on the master cylinder with it and never have problems again.
Bleed the callipers as normal, bleed the top banjo bolt, done.
regards
jon
Honda NC30
Ducati 900 S2 (under constrcution)
Moto Guzzi Le Mans III
Honda CB550F2
BMW R90S
Wacko Jacko
Post by Wacko Jacko »
Cheers lads for all your suggestions and support got loads of things to try now. Spot on advice!
