new ZXR owner advice needed. please help
- Reactions:
Hi guys,
I know I should post this in the kawasaki section, which I did but I really need so advice and I am really worried and concerned because of the bad experience 1 year ago when I bought a zxr and only had it for 48 hours because I didn't know better and it turned out to be a dog so I sold it 1/2 the price I paid in 48 hrs. So, I just want to see if it happens again to me with this ZXR.
I only have the bike for over a week and something unusual happened today on my way to work and I really need some advice and see if it was me or the bike having problem.
Ok, I love the bike and it a very clean and well looked after bike and everything was perfect but today something unusual happened.
I notice the the idle rpm was lower then the usual 1500rmp (just under 1000rmp) as a result I stall the bike 3 times getting off the traffic and I also notice the temp level only at the 1/4 level throughout the trip even when I was filtering the slowly, usually it is at the 1/2 level.
I am worried! I know lower temp is good for the engine but the unusual low idle rmp and low temp make me feel the bike having problem.
Can you guys advise on this please. It is very cold today and I didn't warm the bike up before my ride (only about 45 seconds) could that be the reason?
- ChowderV4
- Reactions:
Re: new ZXR owner advice needed. please help
the cold could have something to do with the temperature, is the bike spluttering or missfiring at all? have you checked the balancer pipes at the back of the inlets in the head, my idle started going a bit all over the place because one was split.
- Reactions:
Ok, thise morning when I go home from work, I warmed up the bike for about 5-10 mins and the idle rmp still at just under 1000rmp, the temp still cold but I guess that is because of the weather.
There's nothing seem wrong about the idle rmp because when I stopped at the traffic light, it didn't cut out or anything just very quiet not like it used to be when it is at 1500rmp when idle, so the question is should I be worried? but clearly something make the idle rmp dropped either it is a bike problem or the colder weather, I don't know.
Any idea? what is you idle zxr400 rmp?
- Reactions:
You can get a manual from zxr400 world, probably a down load, that should have set up information
- Reactions:
- Bike owned: nc30
Simple things first. Check fuel-?has it been sitting for a while.
- ChowderV4
- Reactions:
standard idle is around 1250rpm i reckon
- Reactions:
So, everything seems to bad to normal today as today is warmer. although I did played with the idle cable but it was too high to about 2000rmp when in idle so I think if I didn't touch it would have been in the normal level and the temp also back to what it used to be.
Can it really be a the weather? I can't believe the cold weather makes the bike react so differently, well I guess maybe because it is a old cabr bike not fuel injection and weather affect it more.
thanks for the replies.
- Reactions:
This bike is new to you so it might need a bit of servicing
- Reactions:
