12mm inline fuel filter...any ideas?
Re: 12mm inline fuel filter...any ideas?
I forget where I got the one I used from, perhaps it was a car filter but I took it off in the end. dont remember it casuing any trouble but it wastn needed and made hooking up tank even more fiddly.Neosophist wrote:It's an NC24, 12mm is correct.dobbslc wrote:Is that the outside or the inside diameter you're measuring?
rumpoldstilskin
- Bike owned: Honda RVF 400 NC35 RT
I'm assuming you have an NC24? Mine was 12mm on that, got a glass cartridge one off eBay. About £8. Worked fine but was a pain to fit as it's a tight space underneath and the filter is about 4.5" long overall. Clean the tank out and then line it with tank liner, maybe have the carbs sonically cleaned?fasttom wrote:Ism convinced 25 years worth of crud is getting into carbs from tank (yes I know there is a mesh style filter in tank)and want to run an inline filter from tank to carbs. Problem is I am struggling to find a reasonably priced fuel filter that will fit the bill. Inlet/outlet to fuel filter needs to be 12mm and filter itself needs to fit nicely under tank. Any ideas anybody?
rumpoldstilskin
I should really read all the posts first :/
