Overflow bottle for carbs
paasker
- Bike owned: Aprilia RS125 Tuono, NC29 race
Hi
I'm in the middle of making my trackday nc29 ready for the Dansih Championship next year. I need to find some kind of overflow bottle for all the pipes that end just behind the the right side of the frame in front of the rear wheel.
Just thought I would ask you guys, maybe someone had made a brilliant solution I could copy
Kind reagards
Martin
Kind reagards
Martin
tanuki
Re: Overflow bottle for carbs
IIRC the pipes you are referring to are carbs, shock and coolant bottle
I am assuming you already have a HRC style bottle for the coolant
The shock one is overkill
And do you have to do the carbs, can you not just run the pipe to your catch tray in your fairing?
FYI my set up was:
Pipe from carbs to oil catch tray
Coolant and cam cover breather to individual bottle mounted behind the clocks
FYI my set up was:
paasker
Thanks for input :)
My shock is to be swapped for a R6 shock, so that pipe will be gone soon.
The regulations state to have a bottle for carb overflow, sadly.
Haven't build a HRC coolant bottle on just yet, but think I have a similar one lying somewhere :)
