RR SP tail mod
arkeye
RR SP tail mod
hi everyone. i am going to buy an RR SP tail fairing and just wanted to know what lights to i need to get to fit to it? can u use the standard ones as ive noticed peoples bikes have different rear lights when having one of these tail fairings fitted?
Re: RR SP tail mod
Your talking about a genuine 3TJ style SP ???
The normal 3TJ light should fit it. I'm not sure how the light mounts though, the 3TJ has it on the subframe which I assume is the same for the SP. You might have to mount it straight onto the bodywork though.
arkeye
Re: RR SP tail mod
no i think its a f'glass replica, ive got the 3en2 model
- Motorcycle Solutions
- Bike owned: Kawasaki ZX9R E1
Re: RR SP tail mod
You can use the 3tj rear lights they have four bolts to hold them on the fairing... it is the small bit of fairing that is attached to the subframe..... :D
oollit
- Bike owned: FZR400RR 3TJ, RF900R
Re: RR SP tail mod
You might be better getting aftermarket LED's tail lights if it is a one piece race copy tail section you are getting. The LED units will be a lot lighter, less bulky and easier to attach to the fibreglass tail section than a light from a different model FZR.
A lot of the LED light units are very thin and can be attached with a couple of bolts or even double sided tape. You don't have to drill huge holes which will weaken the fibreglass tail section.
Try Busters, B+C Express, M&P,etc to see what styles of light are on the market at the moment
I only please one person per day.
Today is not your day, tomorrow isn't looking good either.
Re: RR SP tail mod
a TJ tail unit on a 3en2 .... not sure if it will fit very easily due to the shape of the TJ's frame.
Or do you mean the 400R SP or 2TK model ???
