Koso gauges for nc30
chuckles78
- Bike owned: repsol nc30
Re: WTD koso gauges for nc30
I got the analogue to digital convertor mate they are easy to wire up and set up for the bike give me a p.m if you need to I will be glad to help..
It took me 1 day to fit them..
I did a deal with digital speedos got a water temp sensor and the idiot lights for 34.95 delivered The lights are a bit confusing you have to put nuetral and oil on the right side as they are negative switched and all the others indicators etc on the left as this side is positive switched.. I will explain if you get stuck as this will save you pulling an all nighter with the bike in the kitchen to work it out lol ... (like me lol)
chuckles78
Analogue to digital looks better at the front wheel IMO...
vic-vtrvfr
Cheers, appreciate the offer. I'll keep it in mind when when i get to that stage
I got the usual array of standard sensors with it but dont fancy the look of the magnet at the front wheel so def going for the convertor.
chuckles78
thats the way to go mate....
- jim157
chuckles78
Re: Koso gauges for nc30
Thanks jim....
v4hrc
I've considered replacing the clocks on my NC35 with a Koso unit, just want to know of you use the existing temp sensor or the Koso sensor? I'd rather not cut hoses if I don't have to.
You can use the standard temp sensor
v4hrc
Thanks!
chuckles78
I use the koso one itscrews straight in and there is no cutting of the wires etc plus they ust clip together and it only costs a fiver mate....
