VFR 400 NC21 Help Pls!
damiannunn
- Bike owned: NC21
Hi,
Can someone please post a picture of the gear lever and linkage as it is on the bike as I stupidly didnt take a photo when changing damaged for new and now cannot work out how it goes on properly!
There was a modified NC24 lever on before which makes it hard for me to even work it out.
Any help would be greatly appreciated.
Re: VFR 400 NC21 Help Pls!
Modified lever In what way ?
They are basically the same part and interchangable.
http://images.cmsnl.com/img/partslists/ ... 1_5e6a.gif
Here is the microfiche. You can see from here.
The gear lever and shaft also has a round mark punched into it to help you line it up properly.
Super easy.
Super easy.
damiannunn
- Bike owned: NC21
They drilled a hole into the side of the lever to move the foot bit forwards..?-which created a weak spot so when the wind blew it over - it snapped there.
The first part of the assembly(3 on diagram) from the old linkage has a different angle (a little bigger angle) than my new nc21 part.
Now i know about the markings and have the diagram i think i will just interchange the parts if i cant get the new part to fit.
Thankyou very much.
Thankyou very much.
damiannunn
- Bike owned: NC21
damiannunn wrote:They drilled a hole into the side of the lever to move the foot bit forwards..?-which created a weak spot so when the wind blew it over - it snapped there.
Thankyou very much.
Fixed!
Thanks for you help
