Should I remove my flywheel???!??
bollo
Re: Should I remove my flywheel???!??
that's orsome mate, great to hear you are happy with it. i just took my flywheel off tonight & the stator , just got to find something to fill the slot where the wires / grommet was on the top , i just got a new lithium battery which is physically the same size as the last lithium battery but has more cells & i plan to just put the charger on it between races
- 28hodge
I reckon you will be fine to run it without charging between races and just charge it at the end of a day, as with no lights etc they are powering very little!
Which battery have you got?
bollo
it's a Braile G5S , check out the link (didn't buy from these guys i just googled & found link)
http://www.batterybusiness.com.au/store ... raille-g5s
