NC23 Headlight Problem
400RRJ
- Bike owned: CBR 400 RRJ NC23
I have an electrical issue with my head lights and im not sure whats causing it.
The problem is i have no lights apart from side lights. I do get full beam when pressing the pass / flasher button on the switch gear.
i have check all connections are good, bulbs are fine, and switch gear look good too.
any one got any ideas where to look next??
Re: NC23 Headlight Problem
Going to be knackered switchgear methinks..have you stripped it and WD'd it to death?
400RRJ
i have stripped it but not put wd through it. may try it tonight.
Am i right in thinking the relay situated by the head lights is the hi beam relay? it clicks when i push the pass bauuton but nothing when the headlight switch is turned on.
