Ignition lead help please
- Bike owned: gk76a , 92
Hi guys after having lots of issues getting my bike to run correctly I decided to buy fancy spark plugs for it but it made it very flat to ride , so as I took it apart to swap plugs one of the caps fell apart and the inners were still stuck on the plug so leads are old and knackered ,currently it had duel core blue split fire leads and caps but I need to know we're I can get new leads and caps plus how do I get to coils to change leads , as it stands bike is off the road until it fixed , I am using my fmx 650 at moment but nice weather I want my little suzuki back haha if any one could help that would be brilliant many thanks sean
- Variablevalves suck
Re: Ignition lead help please
You need to remove the tank and then the thermostat housing.
Take an old cap to the local breakers as loads of bikes share, thing i used zxr4 caps on mine.
Thanks for reply , someone in the past had really bodge job , so you were right thermostat removed I could see what was goin on , brought universal ht leads and four straight ngk caps all just screws in easy cheers
